Aller au contenu principal
HP Chromebook 14-ca061dx Display Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-ca061dx Display Replacement, Display: étape 1, image 1 de 3 HP Chromebook 14-ca061dx Display Replacement, Display: étape 1, image 2 de 3 HP Chromebook 14-ca061dx Display Replacement, Display: étape 1, image 3 de 3
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: étape 2, image 1 de 1
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: étape 3, image 1 de 1
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: étape 4, image 1 de 2 HP Chromebook 14-ca061dx Display Replacement: étape 4, image 2 de 2
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: étape 5, image 1 de 2 HP Chromebook 14-ca061dx Display Replacement: étape 5, image 2 de 2
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: étape 6, image 1 de 2 HP Chromebook 14-ca061dx Display Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: étape 7, image 1 de 1
    • Remove the LCD/display panel from the Chromebook frame.
Jean Arevalo
Membre depuis le 10/31/19
778 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
3 membres
6 tutoriels rédigés
Un commentaire
should disconnect the laptop battery first
TJ Kleckner - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 30
Total : 2,621
