Introduction
This is a guide for the HP Chromebook 14-ca061dx. In order to repair any internal pieces, you must remove the keyboard. For this guide, you will need the opening tool, the Phillips 64 bit screwdriver with the PH0 head, and spudger.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$3.99
Flip the Chromebook to the underside with the hinge at the top.
Remove the seven, small rubber stoppers using angled tweezers.
Un commentaire
good afternoon, excuse me, I have a question, I also have the same brand HP Chromebook 14-ca061dx and I just want to know where the anti-write screw is, I want to remove the anti-write screw to install windows 10..
