Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The TouchPad is a vital part for the functioning of a laptop. If it were to become damaged, the device could become very hard to operate making the user have to rely on an external mouse, which is not the idea for a portable device. Use this guide to be able to replace the TouchPad for a HP Chromebook 14-x010wm.
  1. Before starting the fix, make sure the computer is turned off, the power is disconnected, and all external devices are disconnected as well. Close the laptop lid. Turn the laptop upside-down.
    • Before starting the fix, make sure the computer is turned off, the power is disconnected, and all external devices are disconnected as well.
    • Close the laptop lid.
    • Turn the laptop upside-down.
  2. Remove the two larger rubber screw covers. Remove the two smaller rubber screw covers.
    • Remove the two larger rubber screw covers.
    • Remove the two smaller rubber screw covers.
    • Remove the middle rubber screw cover.
  3. Using a Phillips #1 screwdriver, remove the thirteen 5.7 mm screws located on the back of the device as shown.
    • Using a Phillips #1 screwdriver, remove the thirteen 5.7 mm screws located on the back of the device as shown.
  4. Turn the computer right side up with the front facing towards you. Turn the computer right side up with the front facing towards you. Turn the computer right side up with the front facing towards you.
    • Turn the computer right side up with the front facing towards you.
  5. Carefully open the computer’s lid as far as it will go until the back edge of the keyboard cover separates from the base. Opening the lid too far may cause damage to some of the internal pieces of the laptop.
    • Carefully open the computer’s lid as far as it will go until the back edge of the keyboard cover separates from the base.
    • Opening the lid too far may cause damage to some of the internal pieces of the laptop.
  6. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  7. Using a plastic opening tool, pry open along the front edge and the sides of the keyboard cover to separate it from the computer’s base. Carefully lift the keyboard cover from the computer’s base. Lifting the keyboard cover too much may damage the internal cables of the laptop.
    • Using a plastic opening tool, pry open along the front edge and the sides of the keyboard cover to separate it from the computer’s base.
    • Carefully lift the keyboard cover from the computer’s base.
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
  8. Using a spudger, remove the battery cable by slowly pulling the plastic connector towards you. Using a spudger, remove the battery cable by slowly pulling the plastic connector towards you.
    • Using a spudger, remove the battery cable by slowly pulling the plastic connector towards you.
  9. Using a spudger,  lift the black plastic flap of the zero insertion force (ZIF) connector that holds the keyboard cable in place. Disconnect the keyboard cable by pulling it from the system board. Disconnect the keyboard cable by pulling it from the system board.
    • Using a spudger, lift the black plastic flap of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by pulling it from the system board.
  10. Using a spudger,  lift the black plastic flap of the zero insertion force (ZIF) connector that holds the TouchPad cable in place. Disconnect the TouchPad cable by pulling it from the system board. At this point, the keyboard cover should be completely detached from the computer’s base.
    • Using a spudger, lift the black plastic flap of the zero insertion force (ZIF) connector that holds the TouchPad cable in place.
    • Disconnect the TouchPad cable by pulling it from the system board.
    • At this point, the keyboard cover should be completely detached from the computer’s base.
  11. Remove the keyboard cover by sliding it towards you. Turn the keyboard cover upside down. Turn the keyboard cover upside down.
    • Remove the keyboard cover by sliding it towards you.
    • Turn the keyboard cover upside down.
  12. Using a spudger, lift the black plastic flap to release the TouchPad cable from the connector. Disconnect the TouchPad cable by pulling it away from the connector. Disconnect the TouchPad cable by pulling it away from the connector.
    • Using a spudger, lift the black plastic flap to release the TouchPad cable from the connector.
    • Disconnect the TouchPad cable by pulling it away from the connector.
  13. Using a Phillips #000 screwdriver, remove the two 2.4 mm  screws that secure the TouchPad to the keyboard cover. Using a Phillips #000 screwdriver, remove the two 2.4 mm  screws that secure the TouchPad to the keyboard cover.
    • Using a Phillips #000 screwdriver, remove the two 2.4 mm screws that secure the TouchPad to the keyboard cover.
  14. Lift the keyboard cover. The TouchPad will be detached. Lift the keyboard cover. The TouchPad will be detached.
    • Lift the keyboard cover. The TouchPad will be detached.
Thiago Leal Figueira
Membre depuis le 15/02/2017
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 15-2, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 15-2, Remmell Spring 2017
USFT-REMMELL-S17S15G2
4 membres
1 tutoriel rédigé
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 30
Total : 1,083
