Aller au contenu principal
HP Chromebook 14-x013dx Camera Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: étape 1, image 1 de 2 HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: étape 1, image 2 de 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Camera Replacement: étape 2, image 1 de 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Camera Replacement: étape 3, image 1 de 2 HP Chromebook 14-x013dx Camera Replacement: étape 3, image 2 de 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Camera Replacement: étape 4, image 1 de 2 HP Chromebook 14-x013dx Camera Replacement: étape 4, image 2 de 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Camera Replacement: étape 5, image 1 de 3 HP Chromebook 14-x013dx Camera Replacement: étape 5, image 2 de 3 HP Chromebook 14-x013dx Camera Replacement: étape 5, image 3 de 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Camera Replacement, Camera: étape 6, image 1 de 2 HP Chromebook 14-x013dx Camera Replacement, Camera: étape 6, image 2 de 2
    • Disconnect the black and white wires connected to the Wi-Fi module.
    • Remove the wire from the casing.
  7. HP Chromebook 14-x013dx Camera Replacement: étape 7, image 1 de 1
    • Pull the ribbon cable out of socket.
  8. HP Chromebook 14-x013dx Camera Replacement: étape 8, image 1 de 3 HP Chromebook 14-x013dx Camera Replacement: étape 8, image 2 de 3 HP Chromebook 14-x013dx Camera Replacement: étape 8, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners.
  9. HP Chromebook 14-x013dx Camera Replacement: étape 9, image 1 de 2 HP Chromebook 14-x013dx Camera Replacement: étape 9, image 2 de 2
    • Remove the lid out of the laptop.
    • It is helpful to rotate the lid to a 90-degree angle.
  10. HP Chromebook 14-x013dx Camera Replacement: étape 10, image 1 de 1
    • Using the plastic opening tool, pry the left and right side of the top of the lid.
    • It is not necessary to remove the entire frame, only pry the top to expose the camera.
  11. HP Chromebook 14-x013dx Camera Replacement: étape 11, image 1 de 1
    • Using tweezers, gently remove the connection hold the camera in place.
  12. HP Chromebook 14-x013dx Camera Replacement: étape 12, image 1 de 2 HP Chromebook 14-x013dx Camera Replacement: étape 12, image 2 de 2
    • Gently pry the camera mount out of the lid.
    • Lift the camera mount out of the lid.
Eile Woeltje
Membre depuis le 11/06/19
304 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G3, Stella Fall 2019 Membre de l'équipe IUPUI, Team S1-G3, Stella Fall 2019
IUPUI-STELLA-F19S1G3
3 membres
2 tutoriels rédigés
Un commentaire
Thank you, very helpful. You could also just start at Step 10 without removing the display
Douglas Walker - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 769
