Aller au contenu principal
HP Chromebook 14-x013dx I/O Board Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: étape 1, image 1 de 2 HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: étape 1, image 2 de 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx I/O Board Replacement: étape 2, image 1 de 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx I/O Board Replacement: étape 3, image 1 de 2 HP Chromebook 14-x013dx I/O Board Replacement: étape 3, image 2 de 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx I/O Board Replacement: étape 4, image 1 de 2 HP Chromebook 14-x013dx I/O Board Replacement: étape 4, image 2 de 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx I/O Board Replacement: étape 5, image 1 de 3 HP Chromebook 14-x013dx I/O Board Replacement: étape 5, image 2 de 3 HP Chromebook 14-x013dx I/O Board Replacement: étape 5, image 3 de 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: étape 6, image 1 de 2 HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: étape 6, image 2 de 2
    • Unhook the ribbon connecting the I/O board and the battery.
    • To remove the ribbon, lift the latch holding the ribbons in place and then pull them free.
  7. HP Chromebook 14-x013dx I/O Board Replacement: étape 7, image 1 de 2 HP Chromebook 14-x013dx I/O Board Replacement: étape 7, image 2 de 2
    • Remove two 2mm screws from the I/O board using the Phillips PH00 screwdriver.
  8. HP Chromebook 14-x013dx I/O Board Replacement: étape 8, image 1 de 1
    • Lift the I/O board out of the laptop case.
2 autres ont terminé cette réparation.
NHerbert
Membre depuis le 09/28/17
602 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S3-G6, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 475
