Introduction
This guide will assist you in successfully replacing the HP Chromebook 14-x013dx Screen. This requires the removal of the bezel around the screen, as well as 4 screws and the connection to the motherboard. Some of the removed parts have adhesive on them which may need to be reapplied.
Note: The replacement of the screen does not require any prior disassembly of the laptop.
Ce dont vous avez besoin
Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
Remove the two 2mm screws holding the bezel to the laptop case.
3 autres ont terminé cette réparation.
