Aller au contenu principal
HP Chromebook 14-x013dx Screen Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-x013dx Screen Replacement, Screen: étape 1, image 1 de 3 HP Chromebook 14-x013dx Screen Replacement, Screen: étape 1, image 2 de 3 HP Chromebook 14-x013dx Screen Replacement, Screen: étape 1, image 3 de 3
    • Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
    • The nylon strips on the side may be difficult to remove, as they are held on with adhesive. A spudger can be used to help remove these strips before removing with fingers.
    • Remove the two 2mm screws holding the bezel to the laptop case.
  2. HP Chromebook 14-x013dx Screen Replacement: étape 2, image 1 de 2 HP Chromebook 14-x013dx Screen Replacement: étape 2, image 2 de 2
    • Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
  3. HP Chromebook 14-x013dx Screen Replacement: étape 3, image 1 de 2 HP Chromebook 14-x013dx Screen Replacement: étape 3, image 2 de 2
    • Remove glued plastic at the bottom of the cover.
  4. HP Chromebook 14-x013dx Screen Replacement: étape 4, image 1 de 1
    • Once glue is separated, pop out the front cover by pulling upwards on the hinge.
  5. HP Chromebook 14-x013dx Screen Replacement: étape 5, image 1 de 2 HP Chromebook 14-x013dx Screen Replacement: étape 5, image 2 de 2
    • Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
  6. HP Chromebook 14-x013dx Screen Replacement: étape 6, image 1 de 3 HP Chromebook 14-x013dx Screen Replacement: étape 6, image 2 de 3 HP Chromebook 14-x013dx Screen Replacement: étape 6, image 3 de 3
    • Before completely removing the screen, detach the connected located at the bottom of the screen.
    • The connection to be removed should have a barcode marking.
3 autres ont terminé cette réparation.
NHerbert
Membre depuis le 09/28/17
602 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S3-G6, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 1,829
