Aller au contenu principal
HP Chromebook 14-x013dx Speakers Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: étape 1, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: étape 1, image 2 de 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: étape 2, image 1 de 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: étape 3, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement: étape 3, image 2 de 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: étape 4, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement: étape 4, image 2 de 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: étape 5, image 1 de 3 HP Chromebook 14-x013dx Speakers Replacement: étape 5, image 2 de 3 HP Chromebook 14-x013dx Speakers Replacement: étape 5, image 3 de 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: étape 6, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement, Battery: étape 6, image 2 de 2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: étape 7, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement: étape 7, image 2 de 2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: étape 8, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement: étape 8, image 2 de 2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: étape 9, image 1 de 1
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: étape 10, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement, Speakers: étape 10, image 2 de 2
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: étape 11, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement: étape 11, image 2 de 2
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: étape 12, image 1 de 2 HP Chromebook 14-x013dx Speakers Replacement: étape 12, image 2 de 2
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
NHerbert
Membre depuis le 09/28/17
602 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S3-G6, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 233
