Aller au contenu principal
HP Chromebook CB2L Keyboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook CB2L Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Flip the Chromebook over so the blue panels are showing.
    • Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
    • This piece has fragile plastic connectors. Don't damage them.
  2. HP Chromebook CB2L Keyboard Replacement: étape 2, image 1 de 2 HP Chromebook CB2L Keyboard Replacement: étape 2, image 2 de 2
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
  3. HP Chromebook CB2L Keyboard Replacement: étape 3, image 1 de 3 HP Chromebook CB2L Keyboard Replacement: étape 3, image 2 de 3 HP Chromebook CB2L Keyboard Replacement: étape 3, image 3 de 3
    • Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  4. HP Chromebook CB2L Keyboard Replacement: étape 4, image 1 de 2 HP Chromebook CB2L Keyboard Replacement: étape 4, image 2 de 2
    • Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Keyboard Replacement: étape 5, image 1 de 2 HP Chromebook CB2L Keyboard Replacement: étape 5, image 2 de 2
    • Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
    • Grabbing the boards by the edges, remove the motherboard and audio/USB board.
  6. HP Chromebook CB2L Keyboard Replacement: étape 6, image 1 de 3 HP Chromebook CB2L Keyboard Replacement: étape 6, image 2 de 3 HP Chromebook CB2L Keyboard Replacement: étape 6, image 3 de 3
    • Remove the red and blue antennae wires from the SIM card board.
    • Remove the SIM card tray.
    • Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
  7. HP Chromebook CB2L Keyboard Replacement: étape 7, image 1 de 2 HP Chromebook CB2L Keyboard Replacement: étape 7, image 2 de 2
    • Remove the speakers and battery.
  8. HP Chromebook CB2L Keyboard Replacement: étape 8, image 1 de 2 HP Chromebook CB2L Keyboard Replacement: étape 8, image 2 de 2
    • Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
    • Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
Nathan Petrie
Membre depuis le 10/31/18
277 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Harley Fall 2018 Membre de l'équipe IUPUI, Team S1-G4, Harley Fall 2018
IUPUI-HARLEY-F18S1G4
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 186
