Aller au contenu principal
HP Chromebook x360 14-da0011dx Lower Case Replacement
Ce dont vous avez besoin
  1. HP Chromebook x360 14-da0011dx Lower Case Replacement, Lower Case: étape 1, image 1 de 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Lower Case Replacement: étape 2, image 1 de 2 HP Chromebook x360 14-da0011dx Lower Case Replacement: étape 2, image 2 de 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Lower Case Replacement: étape 3, image 1 de 3 HP Chromebook x360 14-da0011dx Lower Case Replacement: étape 3, image 2 de 3 HP Chromebook x360 14-da0011dx Lower Case Replacement: étape 3, image 3 de 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Jake Williamson
Membre depuis le 02/14/23
559 Réputation
4 tutoriels rédigés
Équipe
Un commentaire
Where to get replacement parts for this one?
Aguinaldo Motta - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 75
Total : 320
