Aller au contenu principal
HP Chromebox J5N50UT Bottom Shield Replacement
Ce dont vous avez besoin
  1. HP Chromebox J5N50UT Bottom Shield Replacement, Bottom Cover: étape 1, image 1 de 1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT Bottom Shield Replacement: étape 2, image 1 de 1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT Bottom Shield Replacement: étape 3, image 1 de 1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT Bottom Shield Replacement: étape 4, image 1 de 1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
  5. HP Chromebox J5N50UT Bottom Shield Replacement, Bottom Shield: étape 5, image 1 de 1
    • Lift the two pieces of mylar tape from the bracket.
  6. HP Chromebox J5N50UT Bottom Shield Replacement: étape 6, image 1 de 1
    • Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
  7. HP Chromebox J5N50UT Bottom Shield Replacement: étape 7, image 1 de 1
    • Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
Ashley Marvin
Membre depuis le 09/06/18
685 Réputation
5 tutoriels rédigés
Équipe
Ohio State, Team S1-G3, Whitney Fall 2018 Membre de l'équipe Ohio State, Team S1-G3, Whitney Fall 2018
OSU-WHITNEY-F18S1G3
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 504
