Aller au contenu principal
HP Compaq 2510p Bluetooth Adapter Replacement
Ce dont vous avez besoin
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: étape 1, image 1 de 1
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: étape 2, image 1 de 1
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: étape 3, image 1 de 1
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: étape 4, image 1 de 1
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: étape 5, image 1 de 1
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: étape 6, image 1 de 1
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
3 autres ont terminé cette réparation.
Derek Kohansky
Membre depuis le 10/26/16
297 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 416
