Aller au contenu principal
HP Compaq 515 Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Compaq 515 Wireless Card Replacement, Hard Drive: étape 1, image 1 de 1
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
  2. HP Compaq 515 Wireless Card Replacement: étape 2, image 1 de 1
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
  3. HP Compaq 515 Wireless Card Replacement: étape 3, image 1 de 1
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
  4. HP Compaq 515 Wireless Card Replacement, Wireless Card: étape 4, image 1 de 1
    • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
  5. HP Compaq 515 Wireless Card Replacement: étape 5, image 1 de 1
    • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
  6. HP Compaq 515 Wireless Card Replacement: étape 6, image 1 de 2 HP Compaq 515 Wireless Card Replacement: étape 6, image 2 de 2
    • Slide the wireless card backing towards you to remove it from the laptop.
  7. HP Compaq 515 Wireless Card Replacement: étape 7, image 1 de 1
    • Gently remove the black and white wires that are connected to the wireless card.
    • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
  8. HP Compaq 515 Wireless Card Replacement: étape 8, image 1 de 1
    • Remove the two .4 cm screws with a PH00 bit.
Aleks B
Membre depuis le 03/19/18
337 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 5
Total : 203
