Introduction
We are going to show you how to replace the dead fan in your device.
Ce dont vous avez besoin
Flip the computer over so the backside is facing you.
Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
Slide the battery out.
Flip your device over.
In the center of the bottom of the laptop, there is a panel with two screws. Using the JIS #1 screw head unscrew both.
Lift the panel.
Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
Pull these tabs towards you.
Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
2 autres ont terminé cette réparation.
Un commentaire
Many Thanks!
BTW, my German keyboard was held by a 3rd screw. In step 3, one needs to remove the remaining screw next to the WIFI module as well.
