Aller au contenu principal
HP Compaq 6510b Fan Replacement
Ce dont vous avez besoin
  1. HP Compaq 6510b Fan Replacement, Battery: étape 1, image 1 de 2 HP Compaq 6510b Fan Replacement, Battery: étape 1, image 2 de 2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Fan Replacement, RAM: étape 2, image 1 de 2 HP Compaq 6510b Fan Replacement, RAM: étape 2, image 2 de 2
    • Flip your device over.
    • In the center of the bottom of the laptop, there is a panel with two screws. Using the JIS #1 screw head unscrew both.
    • Lift the panel.
  3. HP Compaq 6510b Fan Replacement: étape 3, image 1 de 3 HP Compaq 6510b Fan Replacement: étape 3, image 2 de 3 HP Compaq 6510b Fan Replacement: étape 3, image 3 de 3
    • The RAM is held down by two prongs. Gently pull them until the RAM pops out of place.
    • Lift the RAM out of place.
  4. HP Compaq 6510b Fan Replacement, Fan: étape 4, image 1 de 1
    • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
    • Pull these tabs towards you.
  5. HP Compaq 6510b Fan Replacement: étape 5, image 1 de 2 HP Compaq 6510b Fan Replacement: étape 5, image 2 de 2
    • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
    • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
  6. HP Compaq 6510b Fan Replacement: étape 6, image 1 de 3 HP Compaq 6510b Fan Replacement: étape 6, image 2 de 3 HP Compaq 6510b Fan Replacement: étape 6, image 3 de 3
    • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
  7. HP Compaq 6510b Fan Replacement: étape 7, image 1 de 3 HP Compaq 6510b Fan Replacement: étape 7, image 2 de 3 HP Compaq 6510b Fan Replacement: étape 7, image 3 de 3
    • Carefully undo the white film the same way you took out the metallic film
    • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
  8. HP Compaq 6510b Fan Replacement: étape 8, image 1 de 2 HP Compaq 6510b Fan Replacement: étape 8, image 2 de 2
    • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
    • Carefully lift the cable out of place that is to the right of it.
  9. HP Compaq 6510b Fan Replacement: étape 9, image 1 de 2 HP Compaq 6510b Fan Replacement: étape 9, image 2 de 2
    • Unscrew these two JIS #1 5mm screws on the fan.
    • Carefully unplug the fans' wires.
    • Remove the fan and put in new one.
2 autres ont terminé cette réparation.
Joseph Noudom
Membre depuis le 03/01/18
569 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G5, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G5
3 membres
5 tutoriels rédigés
Un commentaire
Many Thanks!
BTW, my German keyboard was held by a 3rd screw. In step 3, one needs to remove the remaining screw next to the WIFI module as well.
Torsten Spengler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 11
Total : 1,138
