Aller au contenu principal
HP Compaq 6710b Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Compaq 6710b Wireless Card Replacement, Battery: étape 1, image 1 de 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Wireless Card Replacement, Wireless Card: étape 2, image 1 de 2 HP Compaq 6710b Wireless Card Replacement, Wireless Card: étape 2, image 2 de 2
    • Make sure the computer is off.
    • Using a Phillips #1, unscrew the 5mm screw on the bottom of the laptop
    • Remove the back cover plate.
    • The cover has popping tabs so it might require a small amount of force to remove.
  3. HP Compaq 6710b Wireless Card Replacement: étape 3, image 1 de 2 HP Compaq 6710b Wireless Card Replacement: étape 3, image 2 de 2
    • Using a blue plastic prying tool, gently pry off the 2 connectors.
    • The black cable goes on the connection closer to where the cables originate, while the white cable goes on the farther connection.
  4. HP Compaq 6710b Wireless Card Replacement: étape 4, image 1 de 2 HP Compaq 6710b Wireless Card Replacement: étape 4, image 2 de 2
    • Using the Phillips #1 screwdriver, unscrew the 2 3mm screws.
    • Adaptor is spring-loaded.
    • You can now take out the adaptor.
2 autres ont terminé cette réparation.
Khulan Orgil
Membre depuis le 04/14/15
1 171 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 4-2, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 25
Total : 2,810
