Aller au contenu principal
HP Compaq C700 Fan Replacement
Ce dont vous avez besoin
  1. HP Compaq C700 Fan Replacement, Keyboard: étape 1, image 1 de 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Fan Replacement: étape 2, image 1 de 3 HP Compaq C700 Fan Replacement: étape 2, image 2 de 3 HP Compaq C700 Fan Replacement: étape 2, image 3 de 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Fan Replacement: étape 3, image 1 de 1
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Fan Replacement, Fan: étape 4, image 1 de 1
    • Turn the laptop over so that you see the bottom.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver
  5. HP Compaq C700 Fan Replacement: étape 5, image 1 de 1
    • After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
  6. HP Compaq C700 Fan Replacement: étape 6, image 1 de 1
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  7. HP Compaq C700 Fan Replacement: étape 7, image 1 de 1
    • Remove the covering that houses the RAM modules.
  8. HP Compaq C700 Fan Replacement: étape 8, image 1 de 1
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  9. HP Compaq C700 Fan Replacement: étape 9, image 1 de 1
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  10. HP Compaq C700 Fan Replacement: étape 10, image 1 de 1
    • Gently lift and pull out the card.
  11. HP Compaq C700 Fan Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    • Locate the power button connector wire. (This can be found where the keyboard sits.)
    • Using the tweezers, unhook the wire.
  12. HP Compaq C700 Fan Replacement: étape 12, image 1 de 2 HP Compaq C700 Fan Replacement: étape 12, image 2 de 2
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  13. HP Compaq C700 Fan Replacement: étape 13, image 1 de 2 HP Compaq C700 Fan Replacement: étape 13, image 2 de 2
    • Unplug the remaining wires using the tweezers.
  14. HP Compaq C700 Fan Replacement: étape 14, image 1 de 1
    • Gently pull out the three wires.
  15. HP Compaq C700 Fan Replacement: étape 15, image 1 de 2 HP Compaq C700 Fan Replacement: étape 15, image 2 de 2
    • Locate the four 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  16. HP Compaq C700 Fan Replacement: étape 16, image 1 de 1
    • Unhook the display connector wire.
  17. HP Compaq C700 Fan Replacement: étape 17, image 1 de 1
    • Gently disconnect the display by pulling it upwards.
  18. HP Compaq C700 Fan Replacement: étape 18, image 1 de 1
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  19. HP Compaq C700 Fan Replacement: étape 19, image 1 de 1
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  20. HP Compaq C700 Fan Replacement: étape 20, image 1 de 1
    • Locate and unplug the touchpad connection using the tweezers.
  21. HP Compaq C700 Fan Replacement: étape 21, image 1 de 3 HP Compaq C700 Fan Replacement: étape 21, image 2 de 3 HP Compaq C700 Fan Replacement: étape 21, image 3 de 3
    • Using the Opening tool, gently pry up the cover and remove it.
  22. HP Compaq C700 Fan Replacement: étape 22, image 1 de 1
    • Unplug the fan wire connection using the tweezers.
  23. HP Compaq C700 Fan Replacement: étape 23, image 1 de 1
    • Locate the 3 mm Phillips head screw.
    • Unscrew it using the PH0 screwdriver.
  24. HP Compaq C700 Fan Replacement: étape 24, image 1 de 2 HP Compaq C700 Fan Replacement: étape 24, image 2 de 2
    • Using the opening tool, gently pry up and remove the fan.
Taylor Johansen
Membre depuis le 10/20/16
690 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 16
Total : 1,370
