Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Compaq NC6120 Monitor Replacement
Ce dont vous avez besoin
  1. HP Compaq NC6120 Monitor Replacement, Monitor: étape 1, image 1 de 2 HP Compaq NC6120 Monitor Replacement, Monitor: étape 1, image 2 de 2
    • Locate and remove four black 5.1mm Phillips #1 screws from the left and right sides of the monitor.
  2. HP Compaq NC6120 Monitor Replacement: étape 2, image 1 de 3 HP Compaq NC6120 Monitor Replacement: étape 2, image 2 de 3 HP Compaq NC6120 Monitor Replacement: étape 2, image 3 de 3
    • Using a small spudger, remove the four black plastic covers from above the monitor, revealing screws underneath.
  3. HP Compaq NC6120 Monitor Replacement: étape 3, image 1 de 1
    • Remove the four screws that were just uncovered. They are 6.2mm 3.0 flathead screws.
  4. HP Compaq NC6120 Monitor Replacement: étape 4, image 1 de 1
    • Pry off the plastic case surrounding the monitor.
    • A spudger may be needed to pry off the case.
  5. HP Compaq NC6120 Monitor Replacement: étape 5, image 1 de 3 HP Compaq NC6120 Monitor Replacement: étape 5, image 2 de 3 HP Compaq NC6120 Monitor Replacement: étape 5, image 3 de 3
    • Remove the black and silver cable, located directly below the monitor.
    • Proceed to pull monitor approximately 10cm away from the back of the laptop case.
  6. HP Compaq NC6120 Monitor Replacement: étape 6, image 1 de 2 HP Compaq NC6120 Monitor Replacement: étape 6, image 2 de 2
    • Remove the grey cable (with yellow tip) connecting the monitor to the back plastic casing and the monitor will be free from the rest of the laptop.
Mateo Cuellar
Membre depuis le 04/08/15
601 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 17-4, Forte Spring 2015 Membre de l'équipe Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 21
30 derniers jours : 56
Total : 1,728
