Aller au contenu principal
HP Compaq Presario V3000 Battery Replacement
  1. HP Compaq Presario V3000 Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Battery Replacement: étape 2, image 1 de 2 HP Compaq Presario V3000 Battery Replacement: étape 2, image 2 de 2
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Battery Replacement: étape 3, image 1 de 2 HP Compaq Presario V3000 Battery Replacement: étape 3, image 2 de 2
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
3 autres ont terminé cette réparation.
Ricky Jaimez
Membre depuis le 07/20/16
369 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team 1-4, Kim SU 2016 Membre de l'équipe University of Memphis, Team 1-4, Kim SU 2016
UM-KIM-SU16S1G4
3 membres
3 tutoriels rédigés
Un commentaire
I need the battery remove switch
Aadhi Dev - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 24
Total : 2,561
