Introduction
Removing the hard drive is required when the drive will no longer boot or when you want to upgrade to a larger capacity drive. This task can seem difficult, but is not as bad as you may think! Using a magnetic project mat to hold and label the screws will come in handy during this replacement.
CAUTION: Always unplug the device from the power source or wall outlet before beginning any replacement work.
Ce dont vous avez besoin
Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
Locate the battery EJECT latch.
Remove the two Phillips #0, 2.0×5.0 mm hard drive access cover screws. Do not remove them fully. The screws will stay in place on the cover plate.
Lift the access cover off and place it to the side out of your way.
3 autres ont terminé cette réparation.
