Aller au contenu principal
HP Compaq Presario V6000 Trackpad Replacement
Ce dont vous avez besoin
  1. HP Compaq Presario V6000 Trackpad Replacement, Trackpad: étape 1, image 1 de 1
    • Use the metal spudger to gently remove the plastic plate from the rest of the top panel.
    • Be careful not to break the plastic tabs connecting the two top panels.
  2. HP Compaq Presario V6000 Trackpad Replacement: étape 2, image 1 de 1
    • Separate the connection of the top piece from the board.
  3. HP Compaq Presario V6000 Trackpad Replacement: étape 3, image 1 de 1
    • Remove the connection from the keyboard to its housing.
  4. HP Compaq Presario V6000 Trackpad Replacement: étape 4, image 1 de 1
    • Separate the power connections.
  5. HP Compaq Presario V6000 Trackpad Replacement: étape 5, image 1 de 1
    • Unravel the wire.
  6. HP Compaq Presario V6000 Trackpad Replacement: étape 6, image 1 de 1
    • Remove the screws connecting the plastic housing to the screen.
    • Use caution when removing the last screen. Do no damage the screen.
  7. HP Compaq Presario V6000 Trackpad Replacement: étape 7, image 1 de 1
    • Make sure to grip the screen tightly and separate the top and bottom.
  8. HP Compaq Presario V6000 Trackpad Replacement: étape 8, image 1 de 2 HP Compaq Presario V6000 Trackpad Replacement: étape 8, image 2 de 2
    • Remove the screws that hold the track pad in place.
    • Remove the track pad.
adam
Membre depuis le 10/11/16
323 Réputation
2 tutoriels rédigés
Équipe
Texas Tech, Team 38-4, Bennett Fall 2016 Membre de l'équipe Texas Tech, Team 38-4, Bennett Fall 2016
TTU-BENNETT-F16S38G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 616
