Introduction
The internal components of the HP 6122 printer are held together by a metal chassis. The ink cartridge can be found inside the printer.
  1. Check to see if the printer is on by identifying whether or not the bottom button on the right face of the computer is green.  If button is green, proceed.  If not, check guide regarding "Turning on Printer."
    • Check to see if the printer is on by identifying whether or not the bottom button on the right face of the computer is green. If button is green, proceed. If not, check guide regarding "Turning on Printer."
  2. Lift open the front panel to gain access to the inside of the computer.  Upon doing this, the printer should respond by moving the print cartridges more toward the center. Lift open the front panel to gain access to the inside of the computer.  Upon doing this, the printer should respond by moving the print cartridges more toward the center.
    • Lift open the front panel to gain access to the inside of the computer. Upon doing this, the printer should respond by moving the print cartridges more toward the center.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Notice the ink cartridges located in the center of the inside of the printer.  Note that the larger cartridge on the left holds the colored ink, and the thinner cartridge on the right holds the black ink.
    • Notice the ink cartridges located in the center of the inside of the printer. Note that the larger cartridge on the left holds the colored ink, and the thinner cartridge on the right holds the black ink.
  5. Remove the color ink cartridge by lifting back the teal plastic cover located on top of the cartridge.  Proceed by repeating this step from the black ink cartridge.  Then grab the pertruding part on the top of the cartridge, and lift cartridges gently out. Remove the color ink cartridge by lifting back the teal plastic cover located on top of the cartridge.  Proceed by repeating this step from the black ink cartridge.  Then grab the pertruding part on the top of the cartridge, and lift cartridges gently out. Remove the color ink cartridge by lifting back the teal plastic cover located on top of the cartridge.  Proceed by repeating this step from the black ink cartridge.  Then grab the pertruding part on the top of the cartridge, and lift cartridges gently out.
    • Remove the color ink cartridge by lifting back the teal plastic cover located on top of the cartridge. Proceed by repeating this step from the black ink cartridge. Then grab the pertruding part on the top of the cartridge, and lift cartridges gently out.
  6. Finish installing new cartridges by shutting front panel.  Upon doing so, the printer should react by moving the cartridges back to where they started (not visible since panel is closed, just listen for it).
    • Finish installing new cartridges by shutting front panel. Upon doing so, the printer should react by moving the cartridges back to where they started (not visible since panel is closed, just listen for it).
Joe
Membre depuis le 14/10/2011
1 Réputation
4 tutoriels rédigés
Équipe
James Madison, Team 2-5, Allen Fall 2011 Membre de l'équipe James Madison, Team 2-5, Allen Fall 2011
JMU-ALLEN-F11S2G5
1 membre
4 tutoriels rédigés
i have done this but my problem not solved,so this post was not work for me.
josephbrown012 - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 2,842
