Aller au contenu principal
HP Deskjet F4480 Top Lid Replacement
Ce dont vous avez besoin
  1. HP Deskjet F4480 Top Lid Replacement, Open front access panel: étape 1, image 1 de 1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Top Lid Replacement, Top Lid: étape 2, image 1 de 1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet F4480 Top Lid Replacement: étape 3, image 1 de 3 HP Deskjet F4480 Top Lid Replacement: étape 3, image 2 de 3 HP Deskjet F4480 Top Lid Replacement: étape 3, image 3 de 3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet F4480 Top Lid Replacement: étape 4, image 1 de 2 HP Deskjet F4480 Top Lid Replacement: étape 4, image 2 de 2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet F4480 Top Lid Replacement: étape 5, image 1 de 3 HP Deskjet F4480 Top Lid Replacement: étape 5, image 2 de 3 HP Deskjet F4480 Top Lid Replacement: étape 5, image 3 de 3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
21 autres ont terminé cette réparation.
Tim
Membre depuis le 01/15/13
184 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-35, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 membres
15 tutoriels rédigés
Un commentaire
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 9,556
