Introduction
If your laptops Fingerprint Scanner is damaged or no longer functioning reliably, use this guide to remove and replace it.
Ce dont vous avez besoin
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
Disconnect the connector from the motherboard with your fingers.
