Aller au contenu principal
HP Elite X2 1013 G3 Solid State Drive Replacement
Ce dont vous avez besoin
  1. HP Elite X2 1013 G3 Solid State Drive Replacement, Screen: étape 1, image 1 de 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Solid State Drive Replacement: étape 2, image 1 de 2 HP Elite X2 1013 G3 Solid State Drive Replacement: étape 2, image 2 de 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Solid State Drive Replacement: étape 3, image 1 de 2 HP Elite X2 1013 G3 Solid State Drive Replacement: étape 3, image 2 de 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Solid State Drive Replacement: étape 4, image 1 de 2 HP Elite X2 1013 G3 Solid State Drive Replacement: étape 4, image 2 de 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Solid State Drive Replacement, Battery: étape 5, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Solid State Drive Replacement: étape 6, image 1 de 1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Solid State Drive Replacement, Solid State Drive: étape 7, image 1 de 1
    • Make sure the device is powered off and the battery is removed before continuing!
    • Using the Phillips #00 Screwdriver, remove the single indicated screw.
  8. HP Elite X2 1013 G3 Solid State Drive Replacement: étape 8, image 1 de 1
    • Gently tilt the drive upward, then firmly pull it out from the motherboard.
    • Pay attention to the orientation of the SSD. Trying to put your replacement SSD in the wrong way could damage the part or the connector.
Kory Haydon
Membre depuis le 04/18/19
259 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S9-G12, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 75
Total : 2,728
