Aller au contenu principal
HP Elite X2 G4 Display Assembly Replacement
Ce dont vous avez besoin
  1. HP Elite X2 G4 Display Assembly Replacement, Display Assembly: étape 1, image 1 de 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite X2 G4 Display Assembly Replacement: étape 2, image 1 de 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite X2 G4 Display Assembly Replacement: étape 3, image 1 de 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite X2 G4 Display Assembly Replacement: étape 4, image 1 de 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite X2 G4 Display Assembly Replacement: étape 5, image 1 de 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
Goncalo Felix
Membre depuis le 10/25/22
325 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 4-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G4
5 membres
3 tutoriels rédigés
Un commentaire
Boa tarde Gonçalo.
Sabe dizer-me onde posso comprar um ecrã original para o meu HP Elite X2 G4?
Obrigado
Pedro Santos
Pedro_Neno - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 614
