Aller au contenu principal
HP Elite x2 1012 G2 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Screen: étape 1, image 1 de 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 2, image 1 de 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 2, image 2 de 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 2, image 3 de 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 3, image 1 de 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 3, image 2 de 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 4, image 1 de 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 5, image 1 de 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 5, image 2 de 3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 5, image 3 de 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 6, image 1 de 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 6, image 2 de 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: étape 7, image 1 de 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: étape 7, image 2 de 2
    • Locate the cameras at the top center of the power and processing unit.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw.
    • Use a spudger tool to lift up the ribbon cable clamps.
    • Be careful not to crease or damage the ribbon cables or connectors.
  8. HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 8, image 1 de 2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: étape 8, image 2 de 2
    • Remove the front-facing camera.
    • Remove the metal bracket securing the rear-facing camera.
    • Remove the rear-facing camera.
WesleyEagleson
Membre depuis le 04/06/19
431 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S13-G13, Wilson Spring 2019 Membre de l'équipe IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 14
Total : 504
