Aller au contenu principal
HP Elite x2 G4 Battery Replacement
Ce dont vous avez besoin
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: étape 1, image 1 de 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: étape 2, image 1 de 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Battery Replacement: étape 3, image 1 de 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Battery Replacement: étape 4, image 1 de 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: étape 5, image 1 de 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: étape 6, image 1 de 1
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: étape 7, image 1 de 1
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: étape 8, image 1 de 1
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
Goncalo Felix
Membre depuis le 10/25/22
325 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 4-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G4
5 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 30
30 derniers jours : 110
Total : 1,422
