Aller au contenu principal
HP EliteBook 1040 G4 Display Replacement
Ce dont vous avez besoin
  1. HP EliteBook 1040 G4 Display Replacement, Display: étape 1, image 1 de 1
    • Wedge an opening tool between the display and the chassis, gently prying around the perimeter until the display completely releases.
  2. HP EliteBook 1040 G4 Display Replacement: étape 2, image 1 de 2 HP EliteBook 1040 G4 Display Replacement: étape 2, image 2 de 2
    • Lift the metal arm, then pull the display ribbon cable directly out of its port.
  3. HP EliteBook 1040 G4 Display Replacement: étape 3, image 1 de 2 HP EliteBook 1040 G4 Display Replacement: étape 3, image 2 de 2
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  4. HP EliteBook 1040 G4 Display Replacement: étape 4, image 1 de 1
    • Remove the hinge cover.
  5. HP EliteBook 1040 G4 Display Replacement: étape 5, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 5 mm black screws that securing the dispaly.
  6. HP EliteBook 1040 G4 Display Replacement: étape 6, image 1 de 2 HP EliteBook 1040 G4 Display Replacement: étape 6, image 2 de 2
    • Lift the display up and out of its housing.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 28
Total : 917
