Aller au contenu principal
HP EliteBook 1040 G4 Speakers Replacement
Ce dont vous avez besoin
  1. HP EliteBook 1040 G4 Speakers Replacement, Back Cover: étape 1, image 1 de 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Speakers Replacement: étape 2, image 1 de 2 HP EliteBook 1040 G4 Speakers Replacement: étape 2, image 2 de 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Speakers Replacement, Battery: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Speakers Replacement: étape 4, image 1 de 2 HP EliteBook 1040 G4 Speakers Replacement: étape 4, image 2 de 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Speakers Replacement: étape 5, image 1 de 2 HP EliteBook 1040 G4 Speakers Replacement: étape 5, image 2 de 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Speakers Replacement, Speakers: étape 6, image 1 de 1
    • Using the Phillips #1 screwdriver, remove the four black 6 mm screws securing the speakers to the device.
  7. HP EliteBook 1040 G4 Speakers Replacement: étape 7, image 1 de 1
    • Disconnect the pin connector from the right side of the speaker assembly.
  8. HP EliteBook 1040 G4 Speakers Replacement: étape 8, image 1 de 1
    • Carefully remove the red and black wires from the black clips in between the two speakers.
  9. HP EliteBook 1040 G4 Speakers Replacement: étape 9, image 1 de 1
    • Remove the speakers from the device.
Hannah DiMartino
Membre depuis le 09/28/21
395 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 4-1, Hunter Fall 2021 Membre de l'équipe Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 484
