Aller au contenu principal
HP EliteBook 1040 G4 Trackpad Replacement
Ce dont vous avez besoin
  1. HP EliteBook 1040 G4 Trackpad Replacement, Back Cover: étape 1, image 1 de 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Trackpad Replacement: étape 2, image 1 de 2 HP EliteBook 1040 G4 Trackpad Replacement: étape 2, image 2 de 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Trackpad Replacement, Battery: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Trackpad Replacement: étape 4, image 1 de 2 HP EliteBook 1040 G4 Trackpad Replacement: étape 4, image 2 de 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Trackpad Replacement: étape 5, image 1 de 2 HP EliteBook 1040 G4 Trackpad Replacement: étape 5, image 2 de 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Trackpad Replacement, Trackpad: étape 6, image 1 de 1
    • Peel back the foam cover to reveal the underside of the trackpad.
  7. HP EliteBook 1040 G4 Trackpad Replacement: étape 7, image 1 de 1
    • Carefully disconnect the white ribbon cable attached to the underside of the trackpad.
  8. HP EliteBook 1040 G4 Trackpad Replacement: étape 8, image 1 de 1
    • Carefully disconnect the black ribbon cable attached to the chassis.
  9. HP EliteBook 1040 G4 Trackpad Replacement: étape 9, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws securing the trackpad.
  10. HP EliteBook 1040 G4 Trackpad Replacement: étape 10, image 1 de 1
    • Lift and remove the trackpad from the device.
Rion Reynolds
Membre depuis le 02/10/22
121 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 312
