Aller au contenu principal
HP EliteBook 1050 G1 Key Replacement
Ce dont vous avez besoin
  1. HP EliteBook 1050 G1 Key Replacement, Key: étape 1, image 1 de 1
    • Find the broken or malfunctioning key on the keyboard.
    • In this guide, we will replace the "ctrl" key, but this guide works for all keys on the keyboard.
  2. HP EliteBook 1050 G1 Key Replacement: étape 2, image 1 de 2 HP EliteBook 1050 G1 Key Replacement: étape 2, image 2 de 2
    • Wedge the spudger under the corner of the key and pry up while moving the spudger along the length of one edge of the key.
    • Repeat this process for three sides of the key you are removing.
    • No matter how gently you attempt to remove the key, it will sound like it is breaking when you pry and remove it from its housing. THIS IS OKAY. The plastic brackets HP uses to keep its keys in place are very loud, but also very durable.
  3. HP EliteBook 1050 G1 Key Replacement: étape 3, image 1 de 1
    • Lift the key manually by the the edge opposite the one side of the key you did not pry off with the spudger.
    • To ensure the easiest possible removal, lift the key up while gently pulling away from the edge that is still in the keyboard.
  4. HP EliteBook 1050 G1 Key Replacement: étape 4, image 1 de 1
    • To replace the key, lay the new key over its housing with the proper orientation and push it down until you hear a click.
    • If the key is not broken, just "sticky" or malfunctioning, procced up to this step. You can now wiggle the white silicon portion of the key's interior around, pushing down on the extended part of the silicon and wiggling it back and forth. Once you have done that, you can replace the key as described above.
    • Furthermore, you can remove any debris from under the keys at this time with a toothpick or a dampened q-tip, which may improve the performance of your keys.
Jacob Osecheck
Membre depuis le 04/15/19
279 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S2-G10, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G10, Maness Spring 2019
CPSU-MANESS-S19S2G10
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 35
30 derniers jours : 159
Total : 4,547
