Aller au contenu principal
HP EliteBook 1050 G1 RAM Replacement
Ce dont vous avez besoin
  1. HP EliteBook 1050 G1 RAM Replacement, RAM: étape 1, image 1 de 2 HP EliteBook 1050 G1 RAM Replacement, RAM: étape 1, image 2 de 2
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Lift open the back panel with a Jimmy.
  2. HP EliteBook 1050 G1 RAM Replacement: étape 2, image 1 de 3 HP EliteBook 1050 G1 RAM Replacement: étape 2, image 2 de 3 HP EliteBook 1050 G1 RAM Replacement: étape 2, image 3 de 3
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 320
