Aller au contenu principal
HP EliteBook 1050 G1 SSD Replacement
Ce dont vous avez besoin
  1. HP EliteBook 1050 G1 SSD Replacement, SSD: étape 1, image 1 de 2 HP EliteBook 1050 G1 SSD Replacement, SSD: étape 1, image 2 de 2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 SSD Replacement: étape 2, image 1 de 1
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
  3. HP EliteBook 1050 G1 SSD Replacement: étape 3, image 1 de 2 HP EliteBook 1050 G1 SSD Replacement: étape 3, image 2 de 2
    • With the screws removed, the SSD should pop up off of the board below.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
    • When re-inserting the new SSDs make sure the white specs labels are facing up.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 489
