Aller au contenu principal
HP EliteBook 820 G3 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP EliteBook 820 G3 Hard Drive Replacement, Back Cover: étape 1, image 1 de 2 HP EliteBook 820 G3 Hard Drive Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Hard Drive Replacement: étape 2, image 1 de 2 HP EliteBook 820 G3 Hard Drive Replacement: étape 2, image 2 de 2
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 2 HP EliteBook 820 G3 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 2
    • Remove the four 3 mm screws from the hard drive using a Phillips #00 screwdriver.
  4. HP EliteBook 820 G3 Hard Drive Replacement: étape 4, image 1 de 2 HP EliteBook 820 G3 Hard Drive Replacement: étape 4, image 2 de 2
    • Slide the hard drive away from the system board connector to disconnect the hard drive from the system board.
    • Place it in a static dissipative bag.
Sarah Bisimwa
Membre depuis le 08/25/22
247 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Class Fall 2022 Membre de l'équipe Gateway, Team 1-1, Class Fall 2022
GCC-CLASS-F22S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 21
30 derniers jours : 72
Total : 1,103
