Aller au contenu principal
HP EliteBook 820 G3 RAM Replacement
Ce dont vous avez besoin
  1. HP EliteBook 820 G3 RAM Replacement, Back Cover: étape 1, image 1 de 2 HP EliteBook 820 G3 RAM Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 RAM Replacement: étape 2, image 1 de 2 HP EliteBook 820 G3 RAM Replacement: étape 2, image 2 de 2
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 RAM Replacement, RAM: étape 3, image 1 de 3 HP EliteBook 820 G3 RAM Replacement, RAM: étape 3, image 2 de 3 HP EliteBook 820 G3 RAM Replacement, RAM: étape 3, image 3 de 3
    • Pull the two clips on either side of the RAM sideways at the same time.
    • The top half of the stick will pop out of its plate.
    • Pull the RAM stick out.
    • Repeat this step with the other RAM stick.
Nubia Pineda
Membre depuis le 08/24/22
76 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-1, Class Fall 2022 Membre de l'équipe Gateway, Team 1-1, Class Fall 2022
GCC-CLASS-F22S1G1
4 membres
5 tutoriels rédigés
Un commentaire
How to reset BIOS password on the HP 820 G3 please? Many thanks.
Jaeram - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 37
Total : 495
