Aller au contenu principal
HP EliteBook 830 G5 Battery Replacement
Ce dont vous avez besoin
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer
    • Disconnect all external devices from the computer.
  1. HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: étape 2, image 1 de 2 HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: étape 2, image 2 de 2
    • Turn the computer upside down on a flat surface.
    • Loosen the five captive screws.
    • Loosen the two inset captive screws.
    • Starting under the display, insert a case removal tool and lift the bottom cover of the computer.
  2. HP EliteBook 830 G5 Battery Replacement, Remove the battery: étape 3, image 1 de 2 HP EliteBook 830 G5 Battery Replacement, Remove the battery: étape 3, image 2 de 2
    • Disconnect the battery cable from the system board.
    • Remove the five Torx T8 2.5×4.0 screws.
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Membre depuis le 04/22/20
40 307 Réputation
16 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
141 membres
17 895 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 26
30 derniers jours : 99
Total : 2,369
