Aller au contenu principal
HP EliteBook 840 Aero G8 Motherboard Replacement
Ce dont vous avez besoin
  1. HP EliteBook 840 Aero G8 Motherboard Replacement, Speakers: étape 1, image 1 de 2 HP EliteBook 840 Aero G8 Motherboard Replacement, Speakers: étape 1, image 2 de 2
    • Turn the laptop upside-down.
    • Remove all five of the 4.48mm housing screws using a Philips #0 screwdriver.
    • Remove the cover using an iFixit opening tool.
  2. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 2, image 1 de 2 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 2, image 2 de 2
    • Using the iFixit opening tool, remove the right-hand side speaker.
    • Using the iFixit opening tool, remove the left-hand side speaker.
  3. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 3, image 1 de 3 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 3, image 2 de 3 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 3, image 3 de 3
    • Using the plastic spudger, disconnect the speaker power cable.
    • Remove the wire from the device apparatus until it is fully isolated. The speaker system can now be removed from the computer to fix or replace as needed.
  4. HP EliteBook 840 Aero G8 Motherboard Replacement, Motherboard: étape 4, image 1 de 3 HP EliteBook 840 Aero G8 Motherboard Replacement, Motherboard: étape 4, image 2 de 3 HP EliteBook 840 Aero G8 Motherboard Replacement, Motherboard: étape 4, image 3 de 3
    • Using the spudger, unplug the battery from the motherboard.
    • Use the PH1 screwdriver to remove the screws from the battery.
    • Set aside the four 4.48mm screws.
    • Remove the battery from the casing.
  5. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 5, image 1 de 1
    • Using the spudger, gently unplug the RTC battery from the motherboard.
  6. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 6, image 1 de 3 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 6, image 2 de 3 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 6, image 3 de 3
    • Using the spudger, unplug the fan power cable from the motherboard.
    • Use the PH1 screwdriver to remove the three 4.48 mm screws.
    • Remove the fan from the computer.
  7. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 7, image 1 de 1
    • Use the PH1 screwdriver to unscrew the heat sink from the motherboard.
    • Remove the heat sink from the computer.
  8. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 8, image 1 de 2 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    • Use ESD-safe tweezers to disconnect the display cables from the WAN module.
    • Using a spudger, disconnect the display power cable from the motherboard.
  9. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 9, image 1 de 2 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 9, image 2 de 2
    • Use a PH1 screwdriver to remove the 4.48 mm screw that secures the WAN card on the left side of the motherboard.
    • Use a PH1 screwdriver to remove the 4.48 mm screw that secures the WLAN card located on the right side of the motherboard.
  10. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 10, image 1 de 2 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 10, image 2 de 2
    • Using the iFixit opening tool, disconnect the camera power cable on the left hand side of the motherboard.
    • Using the iFixit opening tool, disconnect the camera connection cable from the right-hand side of the motherboard.
  11. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 11, image 1 de 1
    • Using a PH1 screwdriver, remove the bracket holding the left side of the motherboard in place. These four screws are the longer of the two types of screws found in this laptop, measuring 4.48mm in length.
  12. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 12, image 1 de 1
    • Using the iFixit opening tool, unplug the USB board from the motherboard.
  13. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 13, image 1 de 1
    • Using the iFixit opening tool, unplug the fingerprint reader from the motherboard.
  14. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 14, image 1 de 1
    • Using the iFixit opening tool, unplug the NFC module from the motherboard.
  15. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 15, image 1 de 1
    • Using the iFixit opening tool, disconnect the click button assembly from the motherboard.
  16. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 16, image 1 de 1
    • Using the iFixit opening tool, disconnect the touchpad from the motherboard.
  17. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 17, image 1 de 1
    • Using tweezers, gently pull on the smart card reader board to disconnect it from the motherboard.
  18. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 18, image 1 de 1
    • Using the iFixit opening tool, disconnect the motherboard's power cable.
  19. HP EliteBook 840 Aero G8 Motherboard Replacement: étape 19, image 1 de 2 HP EliteBook 840 Aero G8 Motherboard Replacement: étape 19, image 2 de 2
    • Use the PH1 screwdriver to remove the two 4.48mm screws from the motherboard.
    • Use the PH1 screwdriver to remove the three 2.52mm screws from the motherboard.
    • You can now remove the motherboard from the computer to replace or fix it, as needed.
2 autres ont terminé cette réparation.
Riley Rustman
Membre depuis le 11/09/23
507 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 2-2, Harley Fall 2023 Membre de l'équipe IUPUI, Team 2-2, Harley Fall 2023
IUPUI-HARLEY-F23S2G2
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 38
Total : 598
