Aller au contenu principal
HP EliteBook 840 Aero G8 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Battery: étape 1, image 2 de 2
    • Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
    • Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
  2. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 2, image 1 de 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    Halberd Spudger
    $2.99
    • Use the Halberd Spudger to remove the cable running along the bottom of the battery
  3. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 3, image 1 de 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Disconnect the cable connected the battery to the motherboard
  4. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 4, image 1 de 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Use a JIS #0 screwdriver to unscrew the four 7 mm screws that secure the battery.
  5. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Slide the battery out of the clips to remove it from the laptop.
  6. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 1 de 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 2 de 2
    Halberd Spudger
    $2.99
    • Use the hook end of the halberd spudger to remove the black and white antenna cables connected to the Wi-Fi card
  7. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 7, image 1 de 2 HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 7, image 2 de 2
    • Use a JIS #0 screwdriver to unscrew the single 2 mm screw that secures the Wi-Fi card.
  8. HP EliteBook 840 Aero G8 Wi-Fi Card Replacement: étape 8, image 1 de 1
    • Disconnect the WiFi card and gently pull it horizontally to free it from the motherboard.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 28
Total : 914
