Aller au contenu principal
HP EliteBook 840 G5 SSD Storage Replacement
Ce dont vous avez besoin
  1. HP EliteBook 840 G5 SSD Storage Replacement, Back Cover: étape 1, image 1 de 2 HP EliteBook 840 G5 SSD Storage Replacement, Back Cover: étape 1, image 2 de 2
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 SSD Storage Replacement: étape 2, image 1 de 3 HP EliteBook 840 G5 SSD Storage Replacement: étape 2, image 2 de 3 HP EliteBook 840 G5 SSD Storage Replacement: étape 2, image 3 de 3
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 SSD Storage Replacement: étape 3, image 1 de 1
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
  4. HP EliteBook 840 G5 SSD Storage Replacement, SSD Storage: étape 4, image 1 de 1
    • Using a Phillips #1 screwdriver, remove the single 2mm screw that holds the SSD storage in place.
  5. HP EliteBook 840 G5 SSD Storage Replacement: étape 5, image 1 de 2 HP EliteBook 840 G5 SSD Storage Replacement: étape 5, image 2 de 2
    • The SSD storage will pop up.
    • Gently pull out the SSD from its slot.
7 autres ont terminé cette réparation.
Lucas Martos-Repath
Membre depuis le 04/23/18
774 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S25-G13, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G13, Maness Spring 2018
CPSU-MANESS-S18S25G13
4 membres
18 tutoriels rédigés
4 commentaires
This guide was very useful.
I have only one to-add: take care of the little SSD screw (at step 4), don’t let it fall to the motherboard. For me it gave a bit of spark and smell.
Zoltán Szabó - Réponse
Very useful guide indeed. To avoid issues issues similar to the above mentioned, it would be better to disconnect battery first.
Another question: can SSD drives with heat sink like WD SN750 Black be installed in this laptop?
Thanks
gdomenico - Réponse
Before removing the SSD, should you not backup what's on that drive in order to reinstall it on the new SSD? Last question, can a replacement SSD be more than just 238 gb on this particular laptop?
mike._.feliciano - Réponse
Should also unplug the battery. Any M2.2280 should be fine.
Daniel Bernardo -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 62
30 derniers jours : 297
Total : 24,653
