Aller au contenu principal
HP EliteBook 840 G7 Display Assembly Replacement
Ce dont vous avez besoin
  1. HP EliteBook 840 G7 Display Assembly  Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Display Assembly  Replacement: étape 2, image 1 de 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Display Assembly  Replacement: étape 3, image 1 de 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Display Assembly  Replacement: étape 4, image 1 de 3 HP EliteBook 840 G7 Display Assembly  Replacement: étape 4, image 2 de 3 HP EliteBook 840 G7 Display Assembly  Replacement: étape 4, image 3 de 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Display Assembly  Replacement: étape 5, image 1 de 3 HP EliteBook 840 G7 Display Assembly  Replacement: étape 5, image 2 de 3 HP EliteBook 840 G7 Display Assembly  Replacement: étape 5, image 3 de 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Display Assembly  Replacement, Display Assembly: étape 6, image 1 de 2 HP EliteBook 840 G7 Display Assembly  Replacement, Display Assembly: étape 6, image 2 de 2
    • Pull up to remove the two coaxial Wi-Fi card connectors.
  7. HP EliteBook 840 G7 Display Assembly  Replacement: étape 7, image 1 de 2 HP EliteBook 840 G7 Display Assembly  Replacement: étape 7, image 2 de 2
    • Pull upwards on the display connector to remove.
  8. HP EliteBook 840 G7 Display Assembly  Replacement: étape 8, image 1 de 2 HP EliteBook 840 G7 Display Assembly  Replacement: étape 8, image 2 de 2
    • Pull or push to remove the bundled cable connector.
  9. HP EliteBook 840 G7 Display Assembly  Replacement: étape 9, image 1 de 2 HP EliteBook 840 G7 Display Assembly  Replacement: étape 9, image 2 de 2
    • Pull upwards to remove the webcam connector.
  10. HP EliteBook 840 G7 Display Assembly  Replacement: étape 10, image 1 de 1
    • Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
  11. HP EliteBook 840 G7 Display Assembly  Replacement: étape 11, image 1 de 2 HP EliteBook 840 G7 Display Assembly  Replacement: étape 11, image 2 de 2
    • Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
  12. HP EliteBook 840 G7 Display Assembly  Replacement: étape 12, image 1 de 2 HP EliteBook 840 G7 Display Assembly  Replacement: étape 12, image 2 de 2
    • Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
  13. HP EliteBook 840 G7 Display Assembly  Replacement: étape 13, image 1 de 3 HP EliteBook 840 G7 Display Assembly  Replacement: étape 13, image 2 de 3 HP EliteBook 840 G7 Display Assembly  Replacement: étape 13, image 3 de 3
    • Open the laptop to a 90 degree angle.
    • Slide the display hinges away to remove the display assembly.
Ligne d'arrivée
Pedro Ramos Espinoza
Membre depuis le 02/10/22
790 Réputation
4 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Spring 2022 Membre de l'équipe Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 117
Total : 2,672
