Aller au contenu principal
HP EliteBook 840 G7 Heatsink Replacement
Ce dont vous avez besoin
  1. HP EliteBook 840 G7 Heatsink Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Heatsink Replacement: étape 2, image 1 de 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Heatsink Replacement: étape 3, image 1 de 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Heatsink Replacement: étape 4, image 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 4, image 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 4, image 3 de 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Heatsink Replacement: étape 5, image 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 5, image 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 5, image 3 de 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Heatsink Replacement, Heatsink: étape 6, image 1 de 2 HP EliteBook 840 G7 Heatsink Replacement, Heatsink: étape 6, image 2 de 2
    • Separate cables from heatsink and fan.
    • Unplug the fan power cable.
  7. HP EliteBook 840 G7 Heatsink Replacement: étape 7, image 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 7, image 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 7, image 3 de 3
    • Use a Phillips # 1 screwdriver to remove the three 5mm screws from the fan housing.
    • Remove the fan from computer.
  8. HP EliteBook 840 G7 Heatsink Replacement: étape 8, image 1 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 8, image 2 de 3 HP EliteBook 840 G7 Heatsink Replacement: étape 8, image 3 de 3
    • Use a Phillips # 1 screwdriver to remove the four 4mm screws from the heatsink.
    • Remove the heat sink from computer.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 37
Total : 883
