Aller au contenu principal
HP EliteBook 840 G7 Trackpad Replacement
Ce dont vous avez besoin
  1. HP EliteBook 840 G7 Trackpad Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Trackpad Replacement: étape 2, image 1 de 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Trackpad Replacement: étape 3, image 1 de 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Trackpad Replacement: étape 4, image 1 de 3 HP EliteBook 840 G7 Trackpad Replacement: étape 4, image 2 de 3 HP EliteBook 840 G7 Trackpad Replacement: étape 4, image 3 de 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Trackpad Replacement: étape 5, image 1 de 3 HP EliteBook 840 G7 Trackpad Replacement: étape 5, image 2 de 3 HP EliteBook 840 G7 Trackpad Replacement: étape 5, image 3 de 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Trackpad Replacement, Trackpad: étape 6, image 1 de 1
    • Unplug the ribbon cables from the track pad assembly.
  7. HP EliteBook 840 G7 Trackpad Replacement: étape 7, image 1 de 2 HP EliteBook 840 G7 Trackpad Replacement: étape 7, image 2 de 2
    • Use the Philips # 1 screwdriver to remove the four 2.2mm screws securing the track pad assembly.
  8. HP EliteBook 840 G7 Trackpad Replacement: étape 8, image 1 de 1
    • Remove the track pad.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 48
Total : 1,035
