Aller au contenu principal
HP EliteBook 850 G5 Battery Replacement
Ce dont vous avez besoin
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover screws: étape 2, image 1 de 1
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
  2. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover: étape 3, image 1 de 1
    • Starting under the middle of the display, pry and lift the bottom cover off the computer. Consider using a spudger.
  3. HP EliteBook 850 G5 Battery Replacement, Disconnect the battery: étape 4, image 1 de 1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  4. HP EliteBook 850 G5 Battery Replacement, Remove the battery: étape 5, image 1 de 1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Max Kletskov
Membre depuis le 04/22/20
40 850 Réputation
16 tutoriels rédigés
Équipe
The Home Depot Membre de l'équipe The Home Depot
Community
18 081 membres
140 tutoriels rédigés
Un commentaire
Super Anleitung. Keine 10 min da war der Akku getauscht inkl. Reinigung 👍🏼
Marcus van Pluer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 57
30 derniers jours : 232
Total : 8,521
