Aller au contenu principal
HP EliteBook 850 G7 Battery Replacement
Ce dont vous avez besoin
  1. HP EliteBook 850 G7 Battery Replacement, Battery: étape 1, image 1 de 2 HP EliteBook 850 G7 Battery Replacement, Battery: étape 1, image 2 de 2
    • To start flip the device so the bottom is facing up
  2. HP EliteBook 850 G7 Battery Replacement: étape 2, image 1 de 2 HP EliteBook 850 G7 Battery Replacement: étape 2, image 2 de 2
    • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
    • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
  3. HP EliteBook 850 G7 Battery Replacement: étape 3, image 1 de 2 HP EliteBook 850 G7 Battery Replacement: étape 3, image 2 de 2
    • Unplug the battery cable
    • Then remove the 4 marked screws.
    • The battery can now be removed
    • For reassembly just follow the directions in reverse
Caleb Pierce
Membre depuis le 04/19/22
1 121 Réputation
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 201
