Aller au contenu principal
HP EliteBook 8530w Hard Drive Replacement
Ce dont vous avez besoin
  1. HP EliteBook 8530w Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP EliteBook 8530w Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Hard Drive Replacement: étape 2, image 1 de 2 HP EliteBook 8530w Hard Drive Replacement: étape 2, image 2 de 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
  3. HP EliteBook 8530w Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the two screws from the hard drive cover using a Phillips #00 screwdriver.
  4. HP EliteBook 8530w Hard Drive Replacement: étape 4, image 1 de 2 HP EliteBook 8530w Hard Drive Replacement: étape 4, image 2 de 2
    • Use a finger or spudger to lift the edge of the hard drive cover that was screwed down.
    • Remove the cover.
  5. HP EliteBook 8530w Hard Drive Replacement: étape 5, image 1 de 3 HP EliteBook 8530w Hard Drive Replacement: étape 5, image 2 de 3 HP EliteBook 8530w Hard Drive Replacement: étape 5, image 3 de 3
    • Slide the hard drive to the left to disconnect it from the connector on the right side.
    • Pull the hard drive up and out from the laptop.
    • These images show a piece of cardboard as a stand in for a missing hard drive.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 28
Total : 890
