Introduction
Is your trackpad enabled yet not responding? If so, this is a guide to fix the problem by replacing the trackpad in your HP EliteBook Folio 1020 G1.
Please remember to power down your computer and unplug it to avoid any power surges or shorts. Failing to power down and disconnect the power cable may result in further harm to the laptop or even yourself, so precautions must be taken.
Ce dont vous avez besoin
Étape 1 Lower Case
Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
Unplug the white bundled cable connector that leads from the battery to the motherboard.
