Introduction
If your laptop is overheating and there is no fan noise, it may be in need of a fan replacement. Follow these steps to do so.
Ce dont vous avez besoin
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
Use the same screwdriver to remove the remaining five 3.9 mm screws.
4 autres ont terminé cette réparation.
