Aller au contenu principal
HP EliteBook x360 1030 G3 Solid State Drive Replacement
Ce dont vous avez besoin
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: étape 2, image 1 de 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: étape 3, image 1 de 2 HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: étape 3, image 2 de 2
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: étape 4, image 1 de 1
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: étape 5, image 1 de 1
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
3 autres ont terminé cette réparation.
Pablo Arriola
Membre depuis le 04/22/19
504 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S2-G9, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 membres
16 tutoriels rédigés
3 commentaires
Which SSD is compatible with this computer?
Trinayaan Hariharan - Réponse
Very nice its clear
Fuad Gugsa - Réponse
J'ai un problème de son
Sallpape - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 28
30 derniers jours : 126
Total : 5,909
