Aller au contenu principal
HP EliteBook x360 1030 G3 Wireless Card Replacement
Ce dont vous avez besoin
  1. HP EliteBook x360 1030 G3 Wireless Card Replacement, Bottom Cover: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Wireless Card Replacement: étape 2, image 1 de 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: étape 3, image 1 de 2 HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: étape 3, image 2 de 2
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the Wi-Fi and Bluetooth antennas.
    • Take note of which wire goes where, as mixing these cables will cause both Wi-Fi and Bluetooth to stop working.
  4. HP EliteBook x360 1030 G3 Wireless Card Replacement: étape 4, image 1 de 1
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Wireless Card Replacement: étape 5, image 1 de 2 HP EliteBook x360 1030 G3 Wireless Card Replacement: étape 5, image 2 de 2
    • Carefully pull out the card by sliding it to the left.
Shea Charkowsky
Membre depuis le 04/15/19
786 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S2-G9, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 48
Total : 2,202
